Drywall not showing in render
Fotis1960
Go to solution Solved by DBCooper,
Hey everyone
Amateur here. Helping a friend design living space in part of a pole building. I have 2 questions.
1. I created the pole building walls and they work fine. I made a copy and added drywall for the ones that will be in the living space. The drywall is not showing on any of the renderings.
2. I used molding polylines to show the rough in for the water drains for the main floor as they exist. I added proposed water drains for the second floor as he wants it set up. But all of them show on the main level. I can't get the ones on the second floor to show on the second floor.
Any help would be appreciated
Fotis.
Andys Pole Building - Copy.zip
  • Solution
1.  Drywall shows up for me.  Might not show up depending on the layer set you are using.
2.  How did you add the molding polylines to the second floor?  Did you draw them on the floor plan or in a camera view?  If you drew them in the camera view, was your camera set to the 2nd floor when you drew them?  I think the problem is that you somehow put the moldings on the first floor.  You can probably move them to the second floor by using the "cut" edit tool, moving to the second floor and then using the "paste hold position" tool.  You may or may not need to adjust the heights after doing this.
Thank you. Both issues solved.
