JimmyTheJamb Posted 6 hours ago Share Posted 6 hours ago I'm curious if there's a way to associate a 2D CAD block and a 2D symbol to the same object, to be shown under different layer sets/views. For example, we have a bunch of custom electronic devices which I've created 2D CAD blocks from, by importing the 2D SolidWorks file from our engineers. These devices always require the same electrical configuration, located in the same spot relative to the device. I'm trying to simplify the drafting process so that when I place the wireframe of the device in the Working Plan View, the electrical symbol automatically places itself based on where the device was placed when I switch back to the Electrical Plan View. I think I'm effectively looking for a way to make a single object that has 2 different blocks visible depending on which layers are toggled on. I don't need any 3D representation of either block. I've tried this a few ways but can't figure it out, seems like the wire frame and electrical symbol ultimately end up in the same layer set. Is this something that's possible with X16? Thank you! Link to comment Share on other sites More sharing options...
DBCooper Posted 6 hours ago Share Posted 6 hours ago You can assign one cad block to the electrical symbol and then you can place the other cad block into the plan by itself. If the electrical is on one layer and the cad block is on a different layer, then you will have control over which one displays in any plan view. You will need to remember to move both objects together. Link to comment Share on other sites More sharing options...
JimmyTheJamb Posted 6 hours ago Author Share Posted 6 hours ago 13 minutes ago, DBCooper said: You can assign one cad block to the electrical symbol and then you can place the other cad block into the plan by itself. If the electrical is on one layer and the cad block is on a different layer, then you will have control over which one displays in any plan view. You will need to remember to move both objects together. Thank you for the prompt reply DB! This is currently what I've been doing, but I'm trying to avoid having to move them separately to eliminate the "human-error" aspect. Is there no way to tie them together so they move in conjunction in both view sets, yet can be independently toggled? Link to comment Share on other sites More sharing options...
DBCooper Posted 5 hours ago Share Posted 5 hours ago You could maybe create 2 different electrical objects with the 2 different cad blocks and put them on 2 different layers. You could then put both electrical objects in an "architectural block". This way you could treat them like they are one object and still have the ability to display only one at a time. Link to comment Share on other sites More sharing options...
JimmyTheJamb Posted 3 hours ago Author Share Posted 3 hours ago That sounds more like what I'm looking for. After a cursory Google & looking through the CAx16 manual, its not clear how to go about creating Architectural Blocks though. It looks like this is an option with Home Designer Architectural, however I don't see the same options with Chief Architect X16. Where could I find the "Make Architectural Block" icon if it doesn't appear on my lower toolbar and I don't see it in any drop-down menus? Sorry, I'm a bit of a CA noob, so any advice would be greatly appreciated. Thanks! Link to comment Share on other sites More sharing options...
DBCooper Posted 3 hours ago Share Posted 3 hours ago When you have two or more electrical objects selected, you should see the "make architectural block" button. Link to comment Share on other sites More sharing options...
