Jake1976 Posted November 16, 2025 Share Posted November 16, 2025 Alright, I have another odd one here. I have 2 versions of this model that are behaving completely different. One version is not showing any floor edge covering (which is what I want) and the other is showing a floor edge covering (it's the black colored block) I've been told by folks on here to remove the wall edge layer because in the past I've had issues with the finish layer extending down and covering the floor edge. However in this case, it appears to be the wall core that is covering the floor edge. I've checked all of the settings for the railing wall type, the floor properties for the "open to below" room, and the balcony room and I'm not finding what settings are different here. One version is not showing any floor edge covering and the other is (it's the black colored block) I've been told by folks on here to remove the wall edge layer I can send links to the files to download if that's necessary. Let me know. Link to comment Share on other sites More sharing options...
Chrisb222 Posted November 17, 2025 Share Posted November 17, 2025 16 hours ago, Jake1976 said: I can send links to the files to download if that's necessary. Yeah, otherwise people are just guessing. You can post the plan here if you strip it down. But I'll take a stab at it. First thing I would do is compare every detail of the railing wall specs, to look for any difference between them on the two plans. Next I would compare the room definitions defined by that railing wall, again comparing the two plans. Then I'd check for weird wall intersections that popped up when the rooms changed. But yeah, post a plan and you'll get the actual correct answer. Link to comment Share on other sites More sharing options...
Jake1976 Posted November 17, 2025 Author Share Posted November 17, 2025 Ok, I'm not sure how to get the model file sizes down to 14 MB I'd love to know how to do that if anyone wants to let me know. Also, I did exactly this and couldn't find any settings that made the difference: 1 hour ago, Chrisb222 said: I would do is compare every detail of the railing wall specs, to look for any difference between them on the two plans. Next I would compare the room definitions defined by that railing wall, again comparing the two plans Here are dropbox links to them: https://www.dropbox.com/scl/fo/q2jcdp5ucfaigkk8d0tmz/AFrhWaHoWsDYQfdiBFN_Lok?rlkey=7s3eek3sfy9w4nv3if3zwkaqx&dl=0 Link to comment Share on other sites More sharing options...
