EuroDesign Posted November 4, 2025 Share Posted November 4, 2025 Howdy, I don't know what I did wrong here. Everything has been going great up till now. This is an existing one story house, with a 2nd floor and stairway being added to it for our client. I had this set up perfectly until we needed to change the new 2nd floor ceiling height from 9' to 8'. I do not know what I did wrong, but now the wall just above the staircase is doing some really wonky things. I've tried everything to fix it. to make it worse, it will not let me select what appears to be a section of the ceiling and maybe subfloor. The odd stud in the middle of it is caused by the railing somehow. From what I can tell, this is due to the 2nd story wall above. Please help, thanks! Chief Architect - Issue.pdf Link to comment Share on other sites More sharing options...
DBCooper Posted November 4, 2025 Share Posted November 4, 2025 Lot's of things might be going on. Should probably post the plan so someone can poke around in it. You will probably need to make a compressed zip file to post it and might even need to delete things that have nothing to do with the problems (like fixtures and furniture). If it is still too big, you can always post it online somewhere we can download it. Link to comment Share on other sites More sharing options...
