dhurst Posted Monday at 06:19 PM Share Posted Monday at 06:19 PM We have just introduced using window and door schedules on our drawings in lieu of our specifications. I set up my templates and everything appeared to be good until I chose to use them in a new templated. I have set my text to come in using my settings for 1/4" scale, but the callouts are 3-4 times larger than I want. I have "calculate from text" checked but can't figure it out. Any suggestions on additional settings I should check. Link to comment Share on other sites More sharing options...
scottharris Posted yesterday at 03:34 AM Share Posted yesterday at 03:34 AM You might check what Text Style is used for the Label; then adjust it to your desired size. Link to comment Share on other sites More sharing options...
