Ed_Orum Posted October 23, 2025 Share Posted October 23, 2025 Hello again, I have a 3" Minimum between windows in my plan defaults. But, when I push one window against another, instead of stopping at 3", the window simply pushes into the other window. Is there another setting for keeping windows separated by a minimum dimension? Thanks in Advance Link to comment Share on other sites More sharing options...
Solution JKEdmo Posted October 23, 2025 Solution Share Posted October 23, 2025 11 minutes ago, Ed_Orum said: Hello again, I have a 3" Minimum between windows in my plan defaults. But, when I push one window against another, instead of stopping at 3", the window simply pushes into the other window. Is there another setting for keeping windows separated by a minimum dimension? Thanks in Advance Ed, Is your Bumping / Pushing turned off (F11)? Look under Snap Settings. Jim Link to comment Share on other sites More sharing options...
