Framing Overview Always Show Foundation
Sparky66
Using X17 with latest updates.  When I generate either Orthographic or Perspective framing overviews, it only shows floor 0, even if I scroll through 0, 1, and A.  The perspective changes slightly for each floor, but the structure is the same.  Full and Floor overviews display properly for each floor.  Am I missing a setting somewhere or is this a bug.  I have tried rebuilding Walls/Floors/Ceilings and also Rebuild 3D.
Did you build the framing?  Framing will only show up in framing overviews after you build it and it doesn't get built with the walls/floors/ceilings.  It is possible to setup the program to build the framing automatically but the default OOB settings have this turned off.  Turning on auto rebuild framing can also cause some lag if you have a complicated plan so personally I only build it when I need it.
