Sparky66 Posted October 19, 2025 Share Posted October 19, 2025 Using X17 with latest updates. When I generate either Orthographic or Perspective framing overviews, it only shows floor 0, even if I scroll through 0, 1, and A. The perspective changes slightly for each floor, but the structure is the same. Full and Floor overviews display properly for each floor. Am I missing a setting somewhere or is this a bug. I have tried rebuilding Walls/Floors/Ceilings and also Rebuild 3D. Link to comment Share on other sites More sharing options...
DBCooper Posted October 19, 2025 Share Posted October 19, 2025 Did you build the framing? Framing will only show up in framing overviews after you build it and it doesn't get built with the walls/floors/ceilings. It is possible to setup the program to build the framing automatically but the default OOB settings have this turned off. Turning on auto rebuild framing can also cause some lag if you have a complicated plan so personally I only build it when I need it. Link to comment Share on other sites More sharing options...
Sparky66 Posted October 20, 2025 Author Share Posted October 20, 2025 Thanks! That was it. This is only my second project, and the first one was about a year ago. It is slowly coming back to me. Link to comment Share on other sites More sharing options...
