Duplex outlet placement on the end of a wall.
KKBKeith
Go to solution Solved by Joe_Carrick,
Hi all, I am trying to place some outlets on the ends of two walls in a remodel project, see first pic for real world location. I am unable to get them to snap to the ends of the two walls you see in the second pic, end of a 9 1/4" thick 40 1/2" H half wall & end of a 9 1/4" thick interior frame wall. Any way to do this easily? Thanks.
IMG_0869.thumb.JPEG.6c7d8c56b3de700e44be339b6135b041.JPEG     KITCHEN_OUTLET.thumb.jpg.a1785151eeca3e413479e493b388fa92.jpg
  • Solution
Posted (edited)
I see 3 options"
  1. It would appear that the wall is actually 3 walls: [ a long_wall - a short_wall - a long_wall. ] If you model it that way you would be able to place the outlet on the short wall.
  2. Model the Wall as a Cabinet (no doors or drawers-finish to match walls) and place the outlet on the end of that Cabinet
  3. Change the outlets' options so that it isn't "Wall Mounted
Edited by Joe_Carrick
1 hour ago, Joe_Carrick said:
I see 3 options"
Thank you kindly. Made it work by unchecking wall mounted & choosing mounts below wall cabinet. Don't know why I didn't see that before. Thanks again, Joe.
