chiefuserken Posted August 20 Share Posted August 20 I just updated to X17, this is the first time I have had to import a 2D dwg file and wanted to trace over the file like in the past selecting intersections or lines. Why does it no longer snap to the imported files? What setting do I need to adjust to be able to select to line objects? Help. Link to comment Share on other sites More sharing options...
DBCooper Posted August 21 Share Posted August 21 Probably has something to do with the settings you used when you imported the file. Maybe you mapped everything onto a layer that is locked? You could try posting either the plan file or the dwg and someone could probably figure it out quickly. Link to comment Share on other sites More sharing options...
JPCompass Posted September 18 Share Posted September 18 We're having the same issue with X17 and no longer being able to snap walls to a newly imported 2D dwg/CAD file. Were you able to find a solution to this? Premier X17 Using Windows Link to comment Share on other sites More sharing options...
