Clark418 Posted August 2, 2025 Share Posted August 2, 2025 When I attempt to auto build my roof over a two story, multi-level house. I cannot get the roof to build, but I get a false roof off to the side with an unusual shape. There is nothing I can identify under the false roof. What am I doing wrong?Frame House Slopped Roof r1_2025_08_02.zip Link to comment Share on other sites More sharing options...
Solution robdyck Posted August 2, 2025 Solution Share Posted August 2, 2025 You have a Baseline Polyline in your plan, it just isn't displayed in the working plan view nor in the roof plan view. Turn on the layer for Roofs, Baseline Polylines. Then, select and delete the roof baseline polyline. OR open the Build Roof Dialog and check Make Roof Baseline Polylines. This will generate a new baseline polyline and the correct roof, but it will not rebuild when walls are moved as that check box is not 'sticky'. Best to delete the baseline and don't use a baseline unless you understand its function and need it for roof edits. Link to comment Share on other sites More sharing options...
Clark418 Posted August 2, 2025 Author Share Posted August 2, 2025 Thank you I would have never figured it out. Link to comment Share on other sites More sharing options...
