Misbehaving Door Casings
Joe_Carrick
I'm not sure why, but sometimes door casings disappear in X6.  It seems to be only with Door Symbols selected from the Library - and then maybe only when converted to a Pocket Slider.  IAE, once it starts to happen then any edit to the door will likely turn off the casings.
It might also be related to using a new plan.  I would need to check to see if saving the plan would make this problem go away.
