OGDesigner Posted Wednesday at 06:56 PM Share Posted Wednesday at 06:56 PM I can see the Custom Field Value in the Object in the library but once I add that object to the plan, that object's field value is blank. I'm trying to get the Custom Field Value of the Object on the plan to show in the Schedule. I have an Item that is showing the field data on the schedule, but it's within a block. Any thoughts are appreciated Link to comment Share on other sites More sharing options...
DBCooper Posted Wednesday at 11:55 PM Share Posted Wednesday at 11:55 PM I just tried this and it worked fine for me. I placed a chair symbol into a plan, added a custom field and value, and then saved it to the library. When I placed it in new plan, it still had all of the info. Might have something to do with the object type. Might have something to do with editing it in the library instead of the plan. Might have something to do with the version of the program you are using. You could try posting the plan to see if someone else has the same problem. Link to comment Share on other sites More sharing options...
OGDesigner Posted Friday at 02:00 PM Author Share Posted Friday at 02:00 PM Thanks DBC. I did figure this out. I had to switch the Schedule tab to show "Include in Schedule As" instead of "Auto Schedule Category" even though it showed correctly. Not sure why but it did work. Link to comment Share on other sites More sharing options...
