Library Object Custom Field Value is not copied when I add that object to my Plan.
OGDesigner
I can see the Custom Field Value in the Object in the library but once I add that object to the plan, that object's field value is blank.
I'm trying to get the Custom Field Value of the Object on the plan to show in the Schedule.
I have an Item that is showing the field data on the schedule, but it's within a block.
Any thoughts are appreciated
I just tried this and it worked fine for me.  I placed a chair symbol into a plan, added a custom field and value, and then saved it to the library.  When I placed it in new plan, it still had all of the info.
Might have something to do with the object type.  Might have something to do with editing it in the library instead of the plan.  Might have something to do with the version of the program you are using.
You could try posting the plan to see if someone else has the same problem.
