Adam_Gibson Posted May 27, 2025 Share Posted May 27, 2025 This is probably simple, but I've not encountered it for a long time and don't remember the solution. While the walls are still present, the rooms are gone, as are their floors. When I turn on wall framing, it has raised about a foot as evidenced by the framing showing up at the bottom of the windows in 3D. Other elements raised too, like the exterior stone and its cap. The plan was created in X16, and I've had the same issue when bringing it forward to X17. The plan is too large to attach here, but if you want to take a look, it can be downloaded here for X17: https://www.dropbox.com/scl/fi/s6clgf0pou6t0vds9nb7b/PELLEGRINO-16-6.caproj?rlkey=wihf3j2ih78g96rdrp336vf53&dl=0 X16 here: https://www.dropbox.com/scl/fi/0r2elzulvmn4t5vfraexp/PELLEGRINO-16.plan?rlkey=7xlf0gu5qbn88j0atjb9k0ees&dl=0 Link to comment Share on other sites More sharing options...
Renerabbitt Posted May 27, 2025 Share Posted May 27, 2025 51 minutes ago, Adam_Gibson said: The plan is too large to attach here Hope you don't mind, sharing back this much much newer version. I dindt understand the issue you were having. maybe its fixed in this version: Link to comment Share on other sites More sharing options...
Adam_Gibson Posted May 27, 2025 Author Share Posted May 27, 2025 I didn't want to trouble you, Rene. I will look at what you sent in the morning. Thanks so much! Link to comment Share on other sites More sharing options...
