DraftingWCC Posted Tuesday at 01:11 PM Share Posted Tuesday at 01:11 PM Hello! I use the reference display tool to show my floor joists on my plumbing/mechanical plans. Since I have updated, the sync between the two layer sets is not refreshing. Any ideas on refreshing the layer overlay? Thank you! Link to comment Share on other sites More sharing options...
DBCooper Posted Tuesday at 04:05 PM Share Posted Tuesday at 04:05 PM Your probably not actually using the layer set you want. Double check your reference display settings in your view that doesn't look right. If you can't figure it out, then post your plan. Link to comment Share on other sites More sharing options...
