felipecamacho Posted May 13, 2025 Share Posted May 13, 2025 Hi everyone, I’m trying to remove the concrete foundation wall in Chief Architect, but I want the wood framing to sit directly on top of the cinder block piers. I already have beams under the structure, which are supposed to represent the cinder blocks used as the home’s foundation. What I need help with is: Removing the continuous foundation wall. Ensuring the floor framing (joists/beams) sits directly on top of the block piers. If someone could assist me with this, I would really appreciate it. Thanks in advance! Link to comment Share on other sites More sharing options...
mtldesigns Posted May 14, 2025 Share Posted May 14, 2025 6 hours ago, felipecamacho said: remove the concrete foundation Interesting.. have you tried doing a complete wall, then removing the blank sections with a window pass through? Just throwing something out here. I would think this would keep your framing above, but I'm not guaranteeing that. 1 Link to comment Share on other sites More sharing options...
