deck framing disappears when I delete deck and try and create a new one
Attached is my plan.
On some of my plans when I create a deck and then either delete it or modify it the framing/planks disappear and when I try and create a new deck the framing/planks won't show up.
Is there something I need to do it I delete a deck to fix this problem?
Thanks for the help.
house.zip
Open the room specification and look at the third item from the top.  It will say "Deck".  Click on that and look to the upper right.  There will be an item labeled "automatically regenerate deck framing".  Check that box and it will put the framing and planks back in.
An alternate method it to define the room as something else like a bedroom or closet than change it back to a deck and it will redo the framing and planks.
