pwiref Posted 21 hours ago Share Posted 21 hours ago Hey group. I haven't used Home Designer since 2017 buy am now upgraded to the 2025 version and trying it again. I am looking to remove what is the default crown molding in my plan but can only find the option `no room definition` which also removes the baseboards. Is there an option I`m missing? Link to comment Share on other sites More sharing options...
DBCooper Posted 19 hours ago Share Posted 19 hours ago So Home Designer actually has a separate user forum you can find here: https://hometalk.chiefarchitect.com/ Since it is using the same engine that Chief is using, I think you need to turn off the crown molding in the room dialog rather than the wall dialog. Turning off room definition will just make your wall act like it is not a wall so that you won't get a room. Link to comment Share on other sites More sharing options...
pwiref Posted 15 hours ago Author Share Posted 15 hours ago Oh okay....thanks on both accounts. Link to comment Share on other sites More sharing options...
