bobbylutz42000 Posted May 1, 2025 Share Posted May 1, 2025 I need to create a cut out in the wall that isn't a standard rectangle. I can create with a passthru window and a doorway stacked but then I can't seem to remove the header on the doorway or the bottom of the window. Is there a better approach? Link to comment Share on other sites More sharing options...
MPDesign Posted May 1, 2025 Share Posted May 1, 2025 Welcome to the community, I'm assuming you are using X16. Try 2 doors stacked vertically and mull them together. Add trim if needed with molding line tool in elevation/ cross section view. Link to comment Share on other sites More sharing options...
