StudioLuxe Posted April 17, 2025 Share Posted April 17, 2025 How do I change my settings so that when i change the angle of my cabinets with the rotating icon, it dosent go by 1 degrees but 15 degrees and snaps Link to comment Share on other sites More sharing options...
DBCooper Posted April 17, 2025 Share Posted April 17, 2025 Are your angle snaps turned on? You can usually tell when they are off because you will have a symbol that looks like the angle snaps button following your cursor around. Are you in "alt" mode? You can usually tell because you will see "Alt" following your cursor around. You won't see this if you are just holding down the alt key, or using the right mouse button, or the control button, or maybe even some others. Did you mess around with your allowed angles in your general plan defaults? If you did, this could cause the problem you are seeing. If it's not one of those things, then you might want to post your plan or contact tech support. Link to comment Share on other sites More sharing options...
