LeviSunter Posted April 16, 2025 Share Posted April 16, 2025 Hey everyone, I’m working on a simple remodel plan and noticed that the existing driveway has a slight grade that pushes rainwater toward the garage corner. It’s not a huge slope, but just enough to cause concern for future runoff issues. I was thinking of adding a small channel drain in the design to help with that, but wasn’t sure if it’s worth noting in the actual plans or just something to mention during the build phase. A concrete contractor I chatted with once said even small grading issues can turn into bigger problems if they’re overlooked early on. Thanks in advance! Link to comment Share on other sites More sharing options...
LeviSunter Posted April 16, 2025 Author Share Posted April 16, 2025 23 hours ago, LeviSunter said: Hey everyone, I’m working on a simple remodel plan and noticed that the existing driveway has a slight grade that pushes rainwater toward the garage corner. It’s not a huge slope, but just enough to cause concern for future runoff issues. I was thinking of adding a small channel drain in the design to help with that, but wasn’t sure if it’s worth noting in the actual plans or just something to mention during the build phase. A concrete contractor I chatted with once said even small grading issues can turn into bigger problems if they’re overlooked early on. Thanks in advance! Got some good advice from here: Concrete Contractors Ann Arbor MI I’m also wondering if small fixes like this are usually handled by the concrete crew on-site, or if it’s better to plan them out more clearly ahead of time? Link to comment Share on other sites More sharing options...
CharlesVolz Posted April 16, 2025 Share Posted April 16, 2025 Always put everything in plans...if: You really want it to happen. You want it to happen a certain way. You don't want to pay for it (as a designer). I never want a subcontractor or their employees as a co-designer. Not just because they are probably not qualified, but because they usually have a conflict of interest. They may profit more by building less and building wrong. A detailed note may be sufficient, depending on what it is. It is probably not a small inexpensive detail, if you are talking about a rectangular channel drain with a grating cover, thickened slab, additional reinforcing, etc. Best, Charles 1 Link to comment Share on other sites More sharing options...
