Jambruins Posted April 5, 2025 Share Posted April 5, 2025 Attached is my plan. I am using the lower wall type if split by butting roof but my wall either shows all siding or all drywall. How do I get the exposed upper part to be siding and the lower part of the wall to be drywall? Thanks for the help. house.zip Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 5, 2025 Share Posted April 5, 2025 Go up to the attic level and simply delete your manually modified attic wall. As soon as the wall below regenerates the wall you should be good to go. Link to comment Share on other sites More sharing options...
