text shifts when I print a layout
LINDSAYDAY18
Are you printing to a pdf?  Are you using the Chief Architect "save as pdf" tool?  In any case, it might be a problem with the print drivers.
You could try posting your plan to see if someone gets the same results as you.  They might also be able to figure out if you did something wrong or a way you can fix it.
Here is a very generic tech article about printing to pdf:
https://www.chiefarchitect.com/support/article/KB-00768/creating-a-pdf-document.html
Here is one that has some info about using other pdf print drivers:
https://www.chiefarchitect.com/support/article/KB-00483/pdf-print-driver-information.html
