LINDSAYDAY18 Posted April 4, 2025 Share Posted April 4, 2025 why does the template text shift on one page only of my layout when I print? all of the other pages are printing correctly. Link to comment Share on other sites More sharing options...
DBCooper Posted April 6, 2025 Share Posted April 6, 2025 Are you printing to a pdf? Are you using the Chief Architect "save as pdf" tool? In any case, it might be a problem with the print drivers. You could try posting your plan to see if someone gets the same results as you. They might also be able to figure out if you did something wrong or a way you can fix it. Here is a very generic tech article about printing to pdf: https://www.chiefarchitect.com/support/article/KB-00768/creating-a-pdf-document.html Here is one that has some info about using other pdf print drivers: https://www.chiefarchitect.com/support/article/KB-00483/pdf-print-driver-information.html Link to comment Share on other sites More sharing options...
LINDSAYDAY18 Posted April 10, 2025 Author Share Posted April 10, 2025 I was using the chief architect save as a pdf tool. when you say "post my plan" do you mean upload the .plan or the .layout file? Link to comment Share on other sites More sharing options...
DBCooper Posted April 10, 2025 Share Posted April 10, 2025 You might just need to post the .layout file since that is where the text is having the problem. Link to comment Share on other sites More sharing options...
