ns47njit Posted April 4, 2025 Share Posted April 4, 2025 Why are my lower foundation walls seperate from main wall? How do I fix this. Link to comment Share on other sites More sharing options...
CharlesVolz Posted April 4, 2025 Share Posted April 4, 2025 It is always best to post the plan, since it could be several things. My top guesses since it is so consistent, are: 1. the “Build Platform to Exterior of Layer” setting in the Wall Type Definition DBX> Wall Properties being set to the exterior wall layer (instead of the Main Layer) which make no siding or exterior surface cover the floor platform, 2. the exterior wall layer set as a “Main Layer” in the Wall Type Definition DBX, 3. the exterior wall layer set as a “Framing” layer in the Wall Type Definition DBX, Try those first. Good luck, Charles Link to comment Share on other sites More sharing options...
