Ntag85 Posted March 26, 2025 Share Posted March 26, 2025 How do I create a porch ceiling that isn't floating off the roof? I'm new to chief after using CAD and sketchup for 20 years. I can usually find a solution on google, but this issue keeps coming up on projects. Link to comment Share on other sites More sharing options...
DBCooper Posted March 26, 2025 Share Posted March 26, 2025 Well it probably has to do with your ceiling structure but you will get a much better answer if you post your plan. You will probably need to zip it and make sure it is closed when you do this in order to make it small enough to post. You might also want to delete all of the stuff not needed like the furniture. 1 Link to comment Share on other sites More sharing options...
