BortDesign Posted March 24, 2025 Share Posted March 24, 2025 We were working on one of our plans and turned on the line weights tool on the rightside toolbar. When we selected it, the whole plan files line weights were way too big (as shown in the referenced screenshot), and we have not ever had this issue. As I showed in the screenshots also, when zoomed in the plan is normal. This seems to be a scaling issue, but I dont have a clue what setting that could be. -This issue is happening across multiple comptuers in our office, so it is plan releated. -The plan was a copy from a file of a plan from a past version x12 or 13. We are on x16 Link to comment Share on other sites More sharing options...
DBCooper Posted March 24, 2025 Share Posted March 24, 2025 Look at your preferences and see if your minimum line weight is set to something other than 0. If not that, then look at your "drawing sheet setup" to see if everything is set up properly. If neither of those help, then post the plan. Link to comment Share on other sites More sharing options...
