TSutton Posted March 13 Share Posted March 13 I put in the stairwell from lower floor. I use the automatic stairwell tool and it leaves me with the framing (Band Boards) exposed with no drywall. Any help would be great. Link to comment Share on other sites More sharing options...
Solution DBCooper Posted March 13 Solution Share Posted March 13 Check the wall type used for the railing that forms the stairwell room. My guess is that it doesn't have any drywall. Might want to change it to "interior railing" if it is not already. If that doesn't help you, then you should probably post your plan. 1 Link to comment Share on other sites More sharing options...
TSutton Posted March 13 Author Share Posted March 13 Thank you for that. I can't believe that I looked at that for a long time and never thought of checking that. Link to comment Share on other sites More sharing options...
