Scottb Posted Wednesday at 08:27 PM Share Posted Wednesday at 08:27 PM I'm trying to import this survey dwg file and nothing is coming over. This does happen often. Anybody know what to do? ProblematicObjectUtility.cpp(167): Warning #272032858 "195 object(s) are too far away from the origin. We recommend that you delete them or move them closer to the origin, but they will not keep their position relative to other objects in your plan." 03/12/2025 04:23:46 PM Build: 26.3.0.10 macOS Intel 1521 Yonge Street_2018.dwg Link to comment Share on other sites More sharing options...
Alaskan_Son Posted Thursday at 12:34 AM Share Posted Thursday at 12:34 AM I would just ignore the warning. Once imported, Select All and Fill Window. Draw a Marquis around the left hand part of your screen. There's a single text box way out in space over there that just needs to get deleted. Once you do that, you can move the rest to wherever you want. You could optionally also select the Move option during Import which I assume will only screw up the location of the one text box but I'm not totally sure. Link to comment Share on other sites More sharing options...
Scottb Posted Thursday at 01:36 PM Author Share Posted Thursday at 01:36 PM Ironically, I had to uncheck the box, move to (0,0) origin, and it worked! Link to comment Share on other sites More sharing options...
