Sumrall Posted February 25, 2025 Share Posted February 25, 2025 Does any one have a DWG file that I could use to play with in chief architect. I am playing with the idea of buying a plan from Eplans and want to see if it would be worth the money to buy that or if i will need to redrawn the whole plan any way. or if some one has some advice in this that would be great. Link to comment Share on other sites More sharing options...
Gawdzira Posted February 25, 2025 Share Posted February 25, 2025 If you have a pdf to trace, that is probably easier with the exception of a site plan. The walls of a dwg are only cad lines. The walls in a Chief architect file are 3d objects so you are just drawing walls over your cad lines. With a site plan, most of the lines I would use are CAD lines so that would have value. Link to comment Share on other sites More sharing options...
