BenLondon Posted 16 hours ago Share Posted 16 hours ago I am stumped as to how to change the size of the text inside the call out label for an elevation. I succesfully reduced the size of the circle and have tried changing font sizes in MANY places within defaults but with no luck. Guessing this is an easy one...? Link to comment Share on other sites More sharing options...
Solution Chrisb222 Posted 14 hours ago Solution Share Posted 14 hours ago 1 hour ago, BenLondon said: how to change the size of the text inside the call out label for an elevation Usually controlled via the elevation camera layer settings: (Also available in the Active Layer Display Options panel, if you keep that open) You can also simply set your callout to adjust size automatically based on the text size, so the text doesn't exceed the callout: Link to comment Share on other sites More sharing options...
BenLondon Posted 14 hours ago Author Share Posted 14 hours ago Thanks. Found it. I am trying to match the text to the callout vs the other way round because the call out circles are way too big on the plan. Link to comment Share on other sites More sharing options...
