TheoryDesign Posted February 18, 2025 Share Posted February 18, 2025 I'm not a beginner in Chief Arch yet don't think I've experienced this before in version 16. Once I've dropped my elevation views onto sheets in my layout file, and save both, shouldn't those page #'s remain associated with those view in my plan file? If I close the layout file my sheet numbers disappear in my plan file....almost as if they were temporary placeholder spots not confirmed/saved. I admit I'm newer to using the Project Browser to coordinate & navigate my views between the plan & layout files (just never learned the correct way originally) but everything seems fine there. The symbols are also showing as different sizes but assume this is a related problem (missing page numbers that will increase the size of the symbol). Thanks for any thoughts on this. Link to comment Share on other sites More sharing options...
Solution robdyck Posted February 18, 2025 Solution Share Posted February 18, 2025 The camera callouts will display correctly once the layout file is open...and only when the layout file is open. Link to comment Share on other sites More sharing options...
TheoryDesign Posted February 19, 2025 Author Share Posted February 19, 2025 OK thx robdyck guess I've never noticed this b/c I almost always have both open simultaneously. Must be a feature that forces the 2 to constantly coordinate with each other in case of any changes, rather than leaving ghosted information lying around. Smart. 2 Link to comment Share on other sites More sharing options...
