JDSScott Posted February 18, 2025 Share Posted February 18, 2025 Is there a way to make the inside Face of the Cabinet Back with a Tambour Finish Link to comment Share on other sites More sharing options...
MarkMc Posted February 18, 2025 Share Posted February 18, 2025 Cabinet DBX, back, custom, side panel inset. Then select a door symbol. If you have a tambou door symbol use that for the side panel inset. IF you don't but have a material for the tambour then use a slab door symbol that is unique (save to user library with a different name-slab 1) IF neither and you need a tambour symbol I make them from moldings. If you need the back of the cabinet to be different than the inside face of the symbol then you need a symbol with two colors. Link to comment Share on other sites More sharing options...
