mtldesigns Posted Monday at 03:04 AM Share Posted Monday at 03:04 AM I don't get a lot of CMU houses here, let alone a two-story one, but this one I noticed the second floor exterior doors have a header underneath them. Is this typical for a CMU build? BTW, there is a header above the door as there should be. I checked and this is does not have a sill. Like I said, the CMU's I've done prior were single story, so if this is a common thing. Great, I learned something today. But the brain in me, says a header under the door, doesn't make sense. Link to comment Share on other sites More sharing options...
