Fotis1960 Posted February 12, 2025 Share Posted February 12, 2025 I have a fairly complex floor plan and after having auto build a roof I had to make some(lot) of manual changes. Changed some to gable and some to hip. Somewhere along it roof got pretty messed up. When I delete all the roof planes and try to recreate it I get the same messed up roof. Is there a way, after I delete all roof planes, to reset all the walls back to default so I can auto build roof again like it was before all the manual changes. Link to comment Share on other sites More sharing options...
Solution DBCooper Posted February 13, 2025 Solution Share Posted February 13, 2025 You can try using the "reset to defaults" tool and check the box for "roof directives". Link to comment Share on other sites More sharing options...
Fotis1960 Posted February 13, 2025 Author Share Posted February 13, 2025 47 minutes ago, DBCooper said: You can try using the "reset to defaults" tool and check the box for "roof directives". It worked. Thank you. Link to comment Share on other sites More sharing options...
