7thStudio Posted February 8, 2025 Share Posted February 8, 2025 Hi! I am getting this warning all of the sudden constantly in my drawing and it has slowed things down incredibly. Does anyone know what I need to fix? The warning is "Pout number for a slab footing does not match a room pour number. Link to comment Share on other sites More sharing options...
DBCooper Posted February 8, 2025 Share Posted February 8, 2025 Open up a room dialog and go to the structure page. Take a look at the slab pour number for the floor. Now open the wall dialog for each of the walls that are around the room and go to the foundation page. Take a look at the slab pour number for the footings. My guess is that you have a wall somewhere that is using a different pour number than the room is using. The program doesn't seem to like that so try making them the same. If that doesn't help you solve your problem, then post your plan. 1 Link to comment Share on other sites More sharing options...
7thStudio Posted February 9, 2025 Author Share Posted February 9, 2025 Thank you for this step by step. It seems to be okay but nothing improved in terms of the file. Where can I post my plan file? Link to comment Share on other sites More sharing options...
DBCooper Posted February 10, 2025 Share Posted February 10, 2025 You can only attach plan files to this forum if they are less than 14MB. Typically the only way to get them that small is if you first delete all of the stuff that isn't related to the problem (like fixtures and furniture but you might need to delete a lot more) and then make a compressed archive file (such as a .zip file). You need to make sure the plan is closed when you make the zip file otherwise it will be empty. The other thing you can do is put it online somewhere and then post a link to it. Both dropbox and google drive are pretty popular for this kind of thing. Link to comment Share on other sites More sharing options...
