LeutenantDan Posted February 2, 2025 Share Posted February 2, 2025 (edited) I have a step level home, while working on some paneling in the stairs nowhere near the glitching room (see images) I finished my edit and saved my progress before realising something is causing my gable wall to disapear, the roof and all the furniture are floating. Because it is a step level home it has been very difficult having the first floor under the primary elevation, while having a garage and the room above the garage built from the primary elevation up. I think the furniture is floating at the main homes (atic Layer) and an interior wall is now filling where an exterior was (Gray wall on the back side of the home). Also the floor disapeared. It has to be something really easy I'm just not seeing it. Help?! I'm not very good at this. Another issue I have is I lost my bay window. It was built as a room because the "bay window" wouldn't work. After Building the front porch cover it caused the walls to become invisible while the windows remained. I deleted it all because I didn't have the time to fix it. any advice would be much appreciated on both of these issues. Thank you! Home Designer Suite PS: I'm realising that the dining room no longer registers as a room, when I go down a floor to the "garage floor" the stairs are showing as part of the garage? I got it. So much time laps inbetween using the software that i forget the most obvious things. Somehow I disconnected the stairwell from the floor when messing with the doorway to the kitchen at some point. Edited February 3, 2025 by LeutenantDan Figured it out and used soffet for a few misc glitches Link to comment Share on other sites More sharing options...
Mark3D Posted February 5, 2025 Share Posted February 5, 2025 If you can upload your plan file compress if it is big or after compressing it, it is over 14mb dropbox or other cloud share Link to comment Share on other sites More sharing options...
