LAHotShot Posted January 25, 2025 Share Posted January 25, 2025 HELP! I'm missing rafter tails on both the front of my house and the back along the same section. I have tried rebuilding the wall and rebuilding the roof, only for it to wind up with the same missing rafter tails. Link to comment Share on other sites More sharing options...
DBCooper Posted January 26, 2025 Share Posted January 26, 2025 Are you getting the rafters but without the tails or are you not even getting the rafters? Hard to tell from the pictures. If your not getting the rafters, you could always just put them in manually, maybe by copying the ones that are already there. If your getting the rafters but they are not getting the tails, then you should be able to select them and add the tails manually. If this doesn't help, then you probably need to post the plan for someone to poke around in. Link to comment Share on other sites More sharing options...
