JonesNJones Posted January 23, 2025 Share Posted January 23, 2025 Hello all, Can anyone explain this? You can see that one side of the wall extends much further down than the other two layers. I'm at a loss. Thanks! Link to comment Share on other sites More sharing options...
TeaTime Posted January 23, 2025 Share Posted January 23, 2025 The question is why aren't the others building down like that? They all ought to be assuming you have a typical framed floor. That's where your joists will be. Zooming in on your screenshot it looks like all your wall layers are all sitting on top of the OSB. Open up the Definition of those brick walls and make sure all the wall layers are where they ought to be. Everything that should build down to cover your joists should be in the Exterior Layers group. I suspect they're all on the Main Layer. Link to comment Share on other sites More sharing options...
