LotzCC Posted January 13 Share Posted January 13 I have a retaining wall that passes under a deck stair landing. When displayed in the plan view, the retaining wall shows on top of the landing. See attached plan file and image. In another part of the stairs, I you will see another retaining wall that passes under a run of stairs, but does display correctly with the retaining under. Is there a way to get all retaining walls to display under the stairs and landings? Also, automatic breaks are created in the retaining wall where it passes under the landings. Anyway to over ride this? Deck 1.1.2.zip Link to comment Share on other sites More sharing options...
MarkMc Posted January 13 Share Posted January 13 Deleted the walls that made that a room, kept the framing. Added a landing, removed railings and moved it down. and update your signature since that plan wanted to open in X16 Link to comment Share on other sites More sharing options...
LotzCC Posted January 14 Author Share Posted January 14 Thanks Mark. So the key is to make it a stair landing and not a deck level? Link to comment Share on other sites More sharing options...
MarkMc Posted January 14 Share Posted January 14 Yes, making it a room will get you framing so do that first, turn off auto frame, then make landing. The texture you used for the decks is missing so couldn't get that on there but may need another. If you want the doubles on the sides that would take Psolids I think. An alternative might be to break the retaining wall, reverse that section, break again & reverse. Then change the fill for the section under that deck to none. Link to comment Share on other sites More sharing options...
