Drew-PRH Posted 20 hours ago Share Posted 20 hours ago Good day, I'm not able to get these grout lines to be Horizontal - Camara View, Not Elevation View. It wants to do some offsetting. I've tried resizing the applied material to no avail - so I must be doing something wrong (UGH) Who might know how to remedy? I suspect it's easy, I'm just missing it. Thanks - Drew Link to comment Share on other sites More sharing options...
Kreg_Joue Posted 18 hours ago Share Posted 18 hours ago Would you mind posting your plan? Link to comment Share on other sites More sharing options...
Kreg_Joue Posted 18 hours ago Share Posted 18 hours ago If you are talking about the "tile" on the two columns, you might just try stretching your tile in the horizontal until the vertical lines are hidden behind the stone columns. Link to comment Share on other sites More sharing options...
ericepv Posted 8 hours ago Share Posted 8 hours ago You can adjust the positioning of the tile using the 'Adjust material Definition' tool (the rainbow button). In the 'Texture' tab, adjust the tile in the 'Offset & Angle' section. Check out this article (scroll down to the '3 Texture')... https://www.chiefarchitect.com/support/article/KB-01006/customizing-a-library-material.html Link to comment Share on other sites More sharing options...
