MelissaATX Posted January 2 Share Posted January 2 Hi there - I need to create a tile like the one attached, it is a 3" x 9" tile. I tried creating the tile in the Substance Player, but I can't get the scale of the tile and the color quite right. I found the values for R, G, B and entered them exactly but when I import the tile into Chief it is looking very gray. How can I create a better version of this tile? Thank you in advance - Melissa Link to comment Share on other sites More sharing options...
Gawdzira Posted January 3 Share Posted January 3 The actual color is a specification. The color you want to see is something you may have to adjust based on lots of things involved in the rendering and how you will deliver it. Your lighting is affecting this as well as your monitor settings. Remember, always adjust (A), never fudge (F). -Konrad Von Appen (1st and 2nd year prof.) Link to comment Share on other sites More sharing options...
CADustin Posted Friday at 07:00 PM Share Posted Friday at 07:00 PM Hey Melissa, for your scale you'll want the "3:1 Tile" in substance player to match ratios to your 3"x9" Target. Once in Chief, we'll need to count the number of tiles in the image we got from substance player and do a little math to get the Scale in Chief. Number of horizontal tiles x Width of Actual Tile = Chief Scale So for this example we have... 8 tiles across the 3:1 tile layout x 9" wide tile. Scale for the material in Chief should be 72". Because the image is square, the vertical scale value will be the same. Let me know if this helps at all. Link to comment Share on other sites More sharing options...
AlexLifespan Posted Friday at 07:11 PM Share Posted Friday at 07:11 PM Melissa, Here is a 3x9 chamfer subway for you. if the color is off too much you can recolor/blend with texture. Hope this helps! Melissas Chamfer Subway.calibz 1 Link to comment Share on other sites More sharing options...
MelissaATX Posted 23 hours ago Author Share Posted 23 hours ago Oh my gosh Alex, this is great. Thank you so much!!!! How did you do that? Link to comment Share on other sites More sharing options...
AlexLifespan Posted 21 hours ago Share Posted 21 hours ago You are so welcome! I made it using Architextures. Theres a free version that offers quite a bit, but if you want full control of the settings, the paid version is well worth it. I believe its <$100/year. Let me know if you need assistance with any other tiles in the future! Link to comment Share on other sites More sharing options...
