Footeconst3 Posted January 1 Share Posted January 1 I have a 40 x 90 x (16' sidewalls) building with an 18' x 40' office on the right/east side, in the building. The office will have a 4' pony wall with black brick exterior that is stick framed on the front. The rest of the office will be stick framed with siding (16' walls) to the foundation. The front (south) side of the building (remaining 72') will be 4' concrete pony wall with black brick and 12' siding above. The left (west) side will be a 4' cement pony wall with 12' siding above it. The back (north) side will be a 4' cement pony wall with 12' siding above. CA will not let me build the front wall with 72' of cement pony wall, then 18' framed wall all with 4' black brick below. I have tried building separate wall sections and changing materials. It also will not let me do the cement pony wall on three sides of the shop but brick only on the front. I changes the west and north to either have brick or takes the brick off the front. HELP! I'm currently using the latest CA version, same computer system. exterir.pdf Back_north.pdf Link to comment Share on other sites More sharing options...
scottharris Posted January 2 Share Posted January 2 Can you post the plan? And, maybe a diagram of the walls you are trying to build. Link to comment Share on other sites More sharing options...
