LotzCC Posted December 19, 2024 Share Posted December 19, 2024 What determines the bump push distance for a window or door and can the default be adjusted? Link to comment Share on other sites More sharing options...
DBCooper Posted December 20, 2024 Share Posted December 20, 2024 I think they will bump against wall corners and ends based on the casings. There is also a setting in your general plan defaults that allows you to ignore the casing when resizing them. Link to comment Share on other sites More sharing options...
