ElkRivers Posted December 10, 2024 Share Posted December 10, 2024 Hello, I am working on a remodel and we're adding 2-1/2" of exterior insulation and a 3/4" rain screen to the exterior of existing 2x4 stud walls. I added them to the exterior layer on the wall type. Now I can't get them to render correctly. Does anyone know where I can find a way to change the casing/sash so that it looks correct on the rendering? Thanks! Link to comment Share on other sites More sharing options...
tundra_dweller Posted December 10, 2024 Share Posted December 10, 2024 @ElkRivers You're probably going to have to play around with the recessed to wall and jamb/frame settings on your doors & windows. If they're set to recess to the sheathing or main layer (options tab in door/window dbx) then I believe that will change where the ext. casings build from. Or you could probably make the casings thicker too. If you're able to post the plan someone could probably give you a better answer. Link to comment Share on other sites More sharing options...
richoffan Posted December 10, 2024 Share Posted December 10, 2024 Hi Karen, In the window DBX you can set the window depth (sort of) by adjusting the inset dimension in Sash. You can spec + or - Link to comment Share on other sites More sharing options...
