AndrewScott Posted November 27, 2024 Share Posted November 27, 2024 I generating timber frame drawings. How can I change my wall panel framing view from the outside to the inside? Link to comment Share on other sites More sharing options...
DBCooper Posted November 27, 2024 Share Posted November 27, 2024 Wall dialog, structure, uncheck "view wall detail from outside". Should be able to change it in your wall defaults if you always want it like this. 1 Link to comment Share on other sites More sharing options...
AndrewScott Posted November 27, 2024 Author Share Posted November 27, 2024 I found it. Its an un click 'view framing from outside button' Click on a wall. Open structures and un click view framing from out side. I should have done this at the start of the design in defaults then its done for all walls automatically Link to comment Share on other sites More sharing options...
AndrewScott Posted November 27, 2024 Author Share Posted November 27, 2024 Thanks DBCooper - I saw your message after i found it. Cheers. 1 Link to comment Share on other sites More sharing options...
