WCjake Posted November 15, 2024 Share Posted November 15, 2024 Anyone out there running a 4070 on X13? I'm looking for stable driver versions that you have been using without issues. Mine was working great for years but in the past months it began to shut down when opening material dialog boxes for wall specifications. From what I've read its probably a result of an Nvidia driver update but when i tried installing older drivers I'm still having the same issue. Just wanted to see what driver versions others are using that have my same setup (x13 and 4070) Thanks! Link to comment Share on other sites More sharing options...
DBCooper Posted November 16, 2024 Share Posted November 16, 2024 I have a 4070 card and I fired up my old X13 version and it seems to run just fine. I only ran it for about 5 minutes though so if problems start happening after a while I might not see them. BTW, another thing to check is to make sure you have the latest X13 update. I have 23.4.1.8 which I think is the last one they put out. My video card driver is below. Link to comment Share on other sites More sharing options...
Solution WCjake Posted November 18, 2024 Author Solution Share Posted November 18, 2024 Thanks, Appreciate the feedback. I checked my X13 version and its the same as yours, so its up to date. I ended up just trying a ton of NVidia drivers and through trial and error eventually found one that worked properly without causing the same crash code. In case anyone else runs into this issue, I found an old game ready driver from 2023 that worked without crashing the program. There might be other ones that work as well but this was the first of 14 drivers(studio and game ready) that worked without my crashing issue. The driver version is 545.92 and was released on oct 26, 2023. Hope this helps if anyone else runs into this problem. Link to comment Share on other sites More sharing options...
