Kentski Posted October 20, 2024 Share Posted October 20, 2024 I have an issue I hope someone could help me with. I tried to put a niche into an 18" wall with 1/2" drywall both sides under a set of stairs. I have attached a photo. As you can see, it worked on one side but not the other. The wall under the stairs is continuous and I have tried a few work arounds; copy and pasting the original niche and trying to build a new one, neither option is working. If anyone has a suggestion I would really the feedback. Cheers, Kent Link to comment Share on other sites More sharing options...
DBCooper Posted October 20, 2024 Share Posted October 20, 2024 Seems to work fine for me. Check to make sure the depth of your niche is correct and if so, you probably need to post your plan. 1 Link to comment Share on other sites More sharing options...
