Mar_Vel Posted October 20, 2024 Share Posted October 20, 2024 Are Chief Architect lineweight thicknesses metric or imperial? What would a lineweight of 10 equate to? Thanks Link to comment Share on other sites More sharing options...
Solution DBCooper Posted October 20, 2024 Solution Share Posted October 20, 2024 Take a look at the drawing sheet setup. If you are using the OOB template plan, then it is set to 1/100 mm. You can change it to something else if you want. Link to comment Share on other sites More sharing options...
Mar_Vel Posted October 20, 2024 Author Share Posted October 20, 2024 4 hours ago, DBCooper said: Take a look at the drawing sheet setup. If you are using the OOB template plan, then it is set to 1/100 mm. You can change it to something else if you want. Thanks. This is the panel I'd been looking for. Link to comment Share on other sites More sharing options...
